-   -   pro top line heads (https://www.racingjunk.com/forums/showthread.php?t=25756)
brandx80 09-19-2009 03:20 PM
pro top line heads
does anyone know if pro top line 360 big block chevy heads are any good?
OneBadGMC 09-19-2009 06:43 PM
The search function is a great thing...
A few have had success, but the majority of us think they're junk Chinese crap.
littlehotrod 09-19-2009 11:18 PM
well them are bad about pulling the rocker studs out..i had a SBChevy Heads and i had 3 studs came out and striped it out and broke it around where the studs go..Me my self i wouldnt get them cause they are junk and not to make u mad but i will never own another set..But now if you wanted to drive them on the street and not turn alot of RPM then they will be good for that..but as far as racing i would stay away from them..But thats me..Its up to you on if u want them or not..
andamo 09-20-2009 06:05 AM
Actually the original heads were made in New Zealand. Their quality control measures were poor and many of the heads, maybe all of them, were released to be sold. They had financial difficulties and RHS ended up buying and re-tooling. I think RHS has dropped the name because of the bad reputation the early heads had. In any case, I'd shy away from them and go with some other known manufacturer.
rabiddawg 09-20-2009 06:06 AM
they make great boat anchors or paper weights
Dahlton 09-22-2009 12:58 AM
My friend used them on his car and they worked good. the quality is not as good as example AFR but neither is the price. (he had the original ones not RHS made)
He had them on a blown 540cid
andamo 09-22-2009 02:48 AM
It seemed there were less problems with the big block heads than the small block stuff. Glad to hear it worked out well for him.
gungho 09-22-2009 03:30 AM
This is true,I guess the best comparison is tools made in china,did you ever use a Chinese socket set?the sockets split,strip,twist,ect.But when you get up over say a 1 1/2" they dont break,low quality material,but plenty of it.the small block stuff had more issues for the same idea..JMO
hammertime 09-22-2009 07:06 AM
there is a good post over on 1320techtalk.com about a head porter talking about how poor these heads were when they came out, and have sense been changed and are not to bad. might be worth a read
blowninjected540 09-22-2009 11:06 AM
I have read that they are good for street applications and show cars but they can not hold up to the stress of racing and big cams. You get what you pay for.
