Its official........
Ok guys I have been kinda looking round for a car to go down the strip with. Now I am getting one. It is a 1993 Mustang GT. I will be dropping in a BBF 460. I got some of the parts already saved so I can get them when I have the money. I am kinda confused and lost on what parts to go with for................
What valves to put in it....it will have a solid rooler cam in it. what oilpan I was thinking putting on a Hogans intake but not sure. What brand radiator to go with also. I have been talking to a couple of the guys on here already bout it and so I am just trying to get soem more input on everything. Thanks guys for the help. |
I forgot to add...
What brand of headers will good to put on it also? |
Valves: Ferrea
Intake: Jon Kaase - http://www.jonkaaseracingengines.com...s/intakes.html Oil Pan: Whatever will fit that has a pass side kickout and full length windage tray. Headers: ??? Radiator: ??? I run a Griffin, but I hear the radiator I bought in 92 is no longer the same quality unit they now make. Supposedly they are now quite a bit 'cheaper' in construction. |
are you installing a new K-member when you put the 460 in? I have Kooks headers on my 91 with a crate 46o, expensive but they fit great. If you get a new K-member its a lot easier to find a pan. I have a Be Cool radiator with a pusher and a puller fan setup. heat is your biggest enemy on the Fox bodies with big blocks...
I know I will prolly have to do some adjusting to the crossmember and all that due ot the ract it had a 351 in it. I cant tell you for sure if I will be putting in a new one without looking at it and just setting the motor in it to see everything that will need to be done to it.
Here are a few pics of the car..........
http://i687.photobucket.com/albums/v...09/Backend.jpg http://i687.photobucket.com/albums/v...nsideStang.jpg http://i687.photobucket.com/albums/v...dinstall-1.jpg http://i687.photobucket.com/albums/v...ontviewish.jpg http://i687.photobucket.com/albums/v...heeliebars.jpg |
I cant tell from the pics but does it still have the stock crossmember? My setup is a QA1, one tube under the motor and lots of room.
http://i330.photobucket.com/albums/l...h_175_7560.jpg |
Here is what the ad says that the body has.......
The Body First, this car is a 1993 mustang GT. The car has all brand new glass all the way around it. mercadize green paint. it has a tubular K member, tubular A arms. Weld drag light front skinny 4.5" with new tires. Custom dash with a complete set of AUTOMETER phantom gauges The car as a ford 9’’ rear end with a 4 link suspension Car has drag racing coilovers all the way around it Has a 12 gallons fuel cell with foam. The rear end has 4:22 scalloped gears with a 31 spline spool The rear axels are MOSER axels Have a complete drag racing seat with 5.0 harness The rear tires are weld drag lights with brand new slicks that have not even touched the pavement. |
you are set since it already has the crossmember!
Your new car is looking good. Keep us informed on the progress.
Chris |
| All times are GMT -8. The time now is 10:21 AM. |
