-   -   Headlight Problem on 66 Pontiac Tempest (https://www.racingjunk.com/forums/showthread.php?t=25794)
jbranontn 09-23-2009 05:35 AM
Replaced headlight switch....I have tail lights , but headlights don't come on...what could be the problem....Brake lights and blinkers work fine.....
topsportsman1 09-23-2009 06:09 AM
Try changing the "dimmer switch" Also check the wiring that goes to the dimmer switch,they get corrosion
THERATTLER 09-23-2009 06:17 AM
I had same problem in a mid 60's car,,,the wires had come unplugged from dimmer switch in floor , everything worked except headlights , ,,Paul
mavrick11211980 10-13-2009 08:03 PM
lights
if it has a pull ot sith thr is an extra conecter if so hook it up again and this time use the other conection
