Engine Build Questions, HP Question, What will it run ??
I know its just a crap shoot ! But here is what i got so far
-350 4 bolt .40 over hence 357 ( lower end of motor all gm ) I'M THINKIN ITS GOOD FOR 6000 RPM ? CORRECT ME IF I'M WRONG ? -flattop 4 relief piston -block has not been decked -Dart iron eagle 180cc, Heads have been shaved to 58cc,2.02/.1.60 -Torker intake ported to match heads -( still need to buy a carb ) -No cam yet i'm thinkin hydraulic flat adv.284 and [email protected] somewhere in that range, SOME INPUT WOULD HELP FOR THIS. - STREET/STRIP MORE ON THE CAR: 80 malibu 4.10 gears 275-60R15 th350 manual valve body ( still need a stall ) Maybe 2500-3000 ???? hookers with 2 1/2 to flowmaster 40's HP GUESS ???? 400 MAYBE ? WHAT WILL IT RUN IN THE EIGHTH ? |
290-325 hp
mid 14's in 1/4 |
350 HP,, IF YOU HAVE ALL THE PARTS YOU LISTED THAT SHOULD RUN 13.0 TO 13.5 'S EASILY. I RAN A 79 MALIBU BACK IN HIGH SCHOOL WITH ALOT LESS PARTS THAN YOU DO, RAN 14.0 WITH HIGHWAY GEARS.. 1/4 MILE... JUST A GUESS, GOOD LUCK.....
350 max prolly like 325, shoud get u into the 12s with that car though. 3000 stall for sure...also go with 3 in exhaust and drop the flows, got with a magnaflow or dynamax ulra flow ul notice a difference
jmo |
I HAVE JUST THE CAM FOR YOU IT IS USED MAYBE 400 STREET MILES AND 20 1/4 MILE PASSES ON IT.
COMP CAMS,PART# 12-250, 284/296DURATION, 507/510 LIFT AND LIFTERS. FLAT TAPPET CAM. MAKE ME AN OFFER. |
| All times are GMT -8. The time now is 08:44 AM. |
