-   -   which block for a sbc 434" DART SHP or BOWTIE, (https://www.racingjunk.com/forums/showthread.php?t=25850)
bowler 09-26-2009 01:00 PM
bowtie block or dart shp block can either one be bored to 4.155?
if both can be used which one would you use? thanks for your help
i would like to sell my donovon block (decked 180,000 ths.) 4.155 bore, crank (3.6250 stroke) and feff johnston aluminum oil pan to build a 434" for next season. Bowler
zipper06 09-26-2009 11:59 PM
Both blocks can be bored to 4.185. NASCAR uses the Bowtie blk. but spend $1,000.00's of dollars preping them.
Carl Hink says the SHP and lil M blk are on sale for the next 3 mos and out of the crate the Dart blks are a better choice. About 3 yrs. ago i bought a Dart lil M blk at a very low price because we bought 4 of them. bored it to 4.155, and put a 4" crank in it with Lonati ProMod rods. Didn't have to grind anywhere on the blk. and used a cheapo 7 qt. trap door pan. I did have to use a small base circle cam, Bullit ground me an .880 B/C cam 4.7 swap with a special grind that i ask for. clearance every where no problems.
hink 09-27-2009 05:36 AM
Dart says the SHP max bore is 4.165
