-   -   Converter stall speed question (https://www.racingjunk.com/forums/showthread.php?t=25921)
coloradoracerguy 10-03-2009 07:30 PM
Just out of curiosity, what stall speeds can you achieve with a 10" converter? I've got a Neal Chance 10" and it needs sent out to be freshened and restalled, but if it can't reach the stall I need (approx 4500-5000), then I might just get a new one. Any input?
Thanks
Mark
russ67chevelle 10-04-2009 04:14 AM
www.dragstuff.com
marty chance is the mediator on the trans dept over there,drop him a line
johnracer 10-04-2009 04:33 AM
That stall speed should be achievable, but you'll get more torque multiplication out of a smaller diameter. Really depends on the application, but I know up here in the thin air you'll need all you can get. I run at Bandimere often and may have seen you there.....
Johnny
coloradoracerguy 10-04-2009 05:59 AM
Thanks for the info. I'll go there and check.
Johnny, what car do you drive? I wasn't racing this year as the car I got needed some chassis updates and that put a damper on the season. I'm hoping to be out there next year though.
Mark
johnracer 10-04-2009 07:00 AM
I mostly run in their Superseries in SG, but occasionally in SP. 63 Vette roadster. Last year it was in tan primer, kinda desert camo looking......had it painted over the winter and is now gray/silver with airbrushed riveted panels on the right front.
If you ran the Chevy event last year, I was the guy that got really crossed up/changed lanes during the first set of TT after it rained all week on the new all concrete track....
What's yours?
Later,
Johnny
coloradoracerguy 10-04-2009 05:40 PM
Didn't have the car last year, just picked it up from my buddy in April. Check out my website, I've got pics there.
www.livinthedreamracing.com
I look forward to racing with ya next year!!
Mark
hammertime 10-04-2009 08:03 PM
You can get the stall change but may cost more then a normal stall change if its way off and needs a big tweak.
I would think you would want more then 4500-5000 though, Loose converters are your friend not tight ones :D
