-   -   reason wilkerson wheels fell off? (https://www.racingjunk.com/forums/showthread.php?t=25965)
delete 10-08-2009 06:25 AM
whats the story on wilkerson wheels flying off?
bbchevy 10-08-2009 07:58 AM
I would SWEAR I seen LugNuts FLYING?But,Maybe the Wheel Studs Broke?
I Looked at the Run Over and Over,LUGNUTS?
Later
G 8)
Harbone 10-08-2009 08:01 AM
I went to the Wilkerson Team blog on the NHRA website and all they really talked about was the crash itself and not what caused it. You think if the lugs were loose something would have happened on the burnout or the initial launch but he was truckin when it happened. Snapped axle, broken diff, who knows?
bbchevy 10-08-2009 08:07 AM
Crash
Not Really!
When you have the 5/8 wheel studs.There at Least 1 1/2 or 2"s of Stud hanging Out of the Lugnut.If they were just Hand Tight,it could have taken the B/Out and the Lauch!
Not SURE What there,PROCEDURE is when they Hang New Rubber???
Later
G 8
With a FULL Floating Rear,IF A Axle Breaks,THE WHEEL Dont Come OFF!!!)
TheYellaBrick 10-08-2009 08:50 AM
Looks like it broke the center out around the multi-mount stud holes.
FullTimeRacing 10-08-2009 08:55 AM
says he watch the guy put the wheels on :shock:
http://www.youtube.com/watch?v=UdrsQpm9Nrs
kod99 10-09-2009 05:51 AM
Maybe they were over torqued and snapped as the car moved sideways a bit.
TheYellaBrick 10-09-2009 07:47 AM
Obviously my observation was totally wrong. SHEARED ALL the studs !!
Could tire shake have started that process of parts departing ?
FullTimeRacing 10-09-2009 08:01 AM
tire shake is to common,material they were made out of is my thoughts
bbchevy 10-09-2009 02:01 PM
Wheels
I Just read that the Reason the the WHEELS Leaving?
Was Because of the Wheel Spacers that were Improperly mounted,that caused the Wheels NOT to be Fully Tightened!!
Later
G 8)
