Alch jetting on 850 Quick Fuel help
I neeed some help on a starting point for jetting.
2600 lbs door car 468 bbc 12.5:1 Oval port heads Mild cam Single plane 176 Glide 488 Gear 850 Quick Fuel Carb Thanks |
168
Thanks, I will start there.
Them carbs can be a bit tricky to get right, do you have a egt or just going to tune by #'s on et slip ?
I have a 468 BBC in a dragster. I have a Quick Fuel 950A carb that came with 160s. I ended up with 168 all around, and messed more with the air and idle mixture. Did you ever say if yours was gas or methanol?
| All times are GMT -8. The time now is 11:11 PM. |
