2.3L 4 cyl
Ok I know it is small but hey looking for some tips on build. Mainly in the head. Looking to build motor for a 3/8 mile 17 Degree banking track.
A lot of the guys that I talk to are using solid lifter, and basically a complete roller. Does any one know about what the max hp you can get out of one of these? I am trying to find tricks or tips to try and be one step ahead of the next guy behind me. The other problem is, that a lot of them all use the same engine builder around here, so I don't think everyone is always getting what they pay for. Any suggestions are greatly appreciated. Thanks. |
i posted this under engines:
in this months carcraft kenny duttweiler builds a 299sbc for a 400mph salt/flats pusher, they call it the baby rat: a 8.5 inch deck dart block, crower steel 2.8 stroke crank, crower rods w/9.5:1 diamond pistons, 4.125 bore, dart little chief heads 235cc rec ports, 2.30/1.55 valves, short duratkions duttweiler cam w/0.850 lift, mild 1.62:1 rockers, EFI, turbocharged, and a hogan's sheet intake. 1,450hp w/another 600hp with an additional 10psi, wow they thinki it will do 430mph :shock: |
"Small" engines can be deceitful. In 1972 Smoky Yunick built a 208 cubic inch small block Chevy for Indy. It was 3.875 bore x 2.200 sroke with a 6.250 rod. From 6,800 to 9,800 rpm, made over 1,000 HP on alcohol.
Now that's buzzing... Dave |
Wow thast pretty neat, BUT guys, but I see no comparrison from the 2 SBC's ya'll mentioned and this guys question on his 2.3 INLINE 4 banger?
Cmon guys help out, or...... |
Ok. First things first. Where is here?? What is the nam eof the shop that builds them. Me personaly have a 2001 celica with a 1.8l. I am going to be building it also aalong with my 93 Stang. Tell us some more info on teh motor will be nice as in OHC and what not.
I know stock they are slugs but they can make decent power with the right parts. Offenhauser makes a nice aluminum intake that you can slap a holley 4 barrel carb on it. |
Ok I am gonna have ot see if I can work some magic at work later on. And find this guy some parts.
Cmon guys help out, or...... these motors, his 4 hole can reach extreme power, i have only rebuilt a line 6 and added a bigger cam and it was awsome going up hills :wink: for a start, competition cams will grind cam for what you want, and you know a bigger cam is a GOOD START 8) |
Look up Racer Walsh on the net.Lots of performance parts for the 2.3L pinto engine..
| All times are GMT -8. The time now is 03:16 PM. |
