-   -   rod length combo. how can this be figured out? (https://www.racingjunk.com/forums/showthread.php?t=26054)
delete 10-16-2009 06:12 AM
how do you figure out what combo a rod length is good for. say i have a rod 6.335 what crank and cubic inch will that work with? there should be a automatic calculator on sight somewhere. standard deck bbc block
russ67chevelle 10-17-2009 01:40 PM
SORRY I MUST OF SCREWED UP SOMEWHERE AND POSTED WRONGLY....
A STANDARD DECK HEIGHT OF BBC IS 9.800 INCHES.TAKE HALF OF THE STROKE U GONNA USE(2" FOR A STANDARD 4"STROKE OF A 454)AND ADD A PISTONS PIN HEIGHT(CENTERLINE OF THE WRIST PIN TO THE PISTON FACE) AND SUBTRACT THE DECK HEIGHT(9.800")THIS BECOMES YOUR REMAINDER.THE REMAINDER IS MAXIMUM ROD LENGTH U CAN USE....GOOD LUCK
