-   -   Distributor gear ware (https://www.racingjunk.com/forums/showthread.php?t=26102)
FullTimeRacing 10-20-2009 09:22 AM
Other then being wore out what would cause a dizzy gear to have exsessive were?
this is none high performance 4.3l gm with 200,000 miles, roller cam
:idea:
curtisreed 10-20-2009 09:51 AM
Re: Distributor gear ware
:idea:
How would one determine what is excessive wear on something that has 200,000 miles?
FullTimeRacing 10-20-2009 10:00 AM
of all the intakes I've pulled off I never seen a gear with teeth worn allmost all the way off
zipper06 10-20-2009 03:15 PM
I'm going to take a stab at this one, i'm guessing the timing chain is very loose and getting a lot of bouncing around, also take a look at the cam gear it may be just as bad.
just a thought
lively 10-20-2009 04:04 PM
i agree--a loose timing system can play havoc with a distributor :oops: :oops:
change it all :shock: :shock: :shock:
LIVELY
rob41willys 10-20-2009 10:22 PM
Is this a counter-balance motor?
FullTimeRacing 10-21-2009 06:22 AM
yes
I looked at the cam I do see some marks on it,so I'm sure it's all junk.
thanks for the talk
MEMRACING62 10-21-2009 01:35 PM
:idea:
I would say at 200.000 miles the whole engine is at the end of the line :wink:
