-   -   Polished Crank (https://www.racingjunk.com/forums/showthread.php?t=26157)
mwilson6 10-26-2009 05:00 PM
Polished Crank
If a steel crank has been polished to a "10-10" just what exactly does that mean? :?:
Thanks
markdunlap 10-26-2009 05:28 PM
Polished crank
It means sombody spent more money on sandpaper than the crank was worth.
Seriously, the crank would be ground .010" undersize, which is the way it is reconditioned when it is no longer usable at standard size. It would then be micro polished with sandpaper or crocus cloth to give it a smooth surface. Trying to polish to a smaller size will result in an out of round shape and unequal bearing clearance.
curtisreed 10-26-2009 05:28 PM
It means the rod journals and the main journals both have been turned .010" of an inch undersized. I hope they turned them and then polished it out.
Curtis
Dang it got treed on that one.
mwilson6 10-26-2009 05:44 PM
Got it, thanks.
