-   -   Ford 8" Question (https://www.racingjunk.com/forums/showthread.php?t=26230)
jreiley 11-03-2009 03:22 PM
Ford 8" Question
I am aware that a 8" is not in the same league with a 9". I have a 29 Ford hot rod with an 8". The current engine puts out 300hp at the read end and I've not had a problem. Is there anything I can do to this rear end to beefen it up to hold more hp?
TS1955 11-03-2009 04:09 PM
If this is a vehicle that is going to be street driven and not have slicks bolted on, I'd leave it alone. JMO!
TS1955
fla1976 11-03-2009 04:18 PM
8"
X2. Unless you plan to race it, I'd be content with the 8 inch.
TheYellaBrick 11-03-2009 05:38 PM
8"er's are actually pretty strong as it is the same design as the 9" with the pinion down low on the ring, hence more gear contact/strength. There are quite a few ratios available as well as limited slip units.
