Roller cam install on BBC
Are all blocks roller compatible or just certain ones? This is my first experience with a BBC.
Thanks, Dave |
Yes, but the gen V and V1 cams have a step on the front for a thrust plate and requires a different timing gear. You may be able to use a button, but for sure the front of the cam is different on a stock engine.
JMO Zip. |
ROLLER CAM IN ANY CHEVY MOTOR...GOTTA HAVE IT!!! I LOVE THE AFTERMARKET WORLD!!! :D
HELL MY STOCK 1981 HARLEY HAS A HYDRAULIC ROLLER SET UP FROM THE FACTORY :shock: |
I you have a real early 396/427 make sure the rear cam bearing is a later model one.
Dave |
| All times are GMT -8. The time now is 05:33 AM. |
