Ericwilkerson the scammer
OLE Eric is still trying to scam.....add #1701282....dont waste your time looking.Everything he says is lies.
I got scammed on a S-10 truck,he said it had good stuff in the engine...it was junk...dont be taken in by this scammer. |
Help
Ok, I'll be the first to ask for some enlightenment????? You need to be more specific, ad #, why you feel he is a scammer yada yada yada. You won't get far without the needed info to make an informed decision on whatever it is you are talking about.
This is your first post! Why didn't you let us know when you actually got screwed? That may have lead to someone else not getting scammed. I emailed Eric to hear what his side is......we'll see hopefully.
I did put it here when it happened....just tryin to help someone else from getting burned by him.
See the $2800 bucks in his profile, he never paid 1 cent to RJ for riping me off for that. This is not my 1st time on here....I just happened to run across the scammers name and a car I seen in his garage in Seymore Ind. where he used to advertise from. |
Did you ever get it figured out or handled?? What name did you use when you put it on here??
Only 2 ive ever used is jgang454 and jgang350 and they were rooled into 1.
I may have posted under this name.
Cool. Did your situation get resolved when you got scammed??
So which one did it roll into jgang350 or jgang454? You posted in this thread under both names. Just curious,,why two names anyway? I am not doubting what you are saying, I am just chewing on a milk bone.
Just to set things straight.. This guy bought an s-10 from me for 2,500. 355 sb 350 th, fuel cell, holley pump, radial slicks, supertrick wheels, new shifter. The engine was just basic with world product iron heads and solid lift camshaft, new holley carb. just the parts alone were worth what he gave for the truck... It was my fathers project and i told him everything i knew to the best of my knowledge.. jgang or( whatever he calls himself now.) came and looked it over and bought it. He then obviously took it home and had second thoughts, because he proceeded to acuse me of screwing him and threatening me.. His complaint was that the engine did'nt have a steel crank as advertised.. I don't know if that was true or not.. But i sent him $200.00 for this issue.. This guy is the typical (I want a prostocker for 2k..) He is now harrassing again on my e-mail... I wont respond to this crap anymore..
Eric Wilkerson |
| All times are GMT -8. The time now is 10:41 PM. |
