CALLIES vs LUNATI
I have a callies magnum II crank that I was planning on using in a blown 540cid but now I have second toughts should I go wit a Lunati Blower crank instead?
Ofcourse the Lunati should be better but will the callies take the beating? Does any one use a callies magnum II crank in a blower engine? does anyone have some experience?? |
If your crank has the double keyway, run it.
Dave |
It is not doubble keyed but it will be if I use it.
The Callies Magnam is USA made and probably every bit as good as the Lunati which is also American made. In fact Callies has been making cranks a lot longer than Lunati has and i would not be afraid to use either one of them with alcohol or nitro.
There are better cranks, but they would be billet and cost 2 to 3 times more. JMO Zip. |
| All times are GMT -8. The time now is 02:35 AM. |
