-   -   Need some Help with a windage tray (https://www.racingjunk.com/forums/showthread.php?t=26447)
jrsmith80 11-23-2009 09:23 AM
I am assembling my short block and am having trouble figuring out where each stud goes to mount my Moroso Louvered Windage Tray. I lost the instructions and need to know which holes the tray mounts with. I got a ARP stud kit and it sure seems like I am missing a stud but ARP tells me that I am not. I know this sounds stupid but I need some help cuz my windage tray is in a different motor about 100 miles away. Thanks in advance.
Here is the windage tray I have:
http://www.summitracing.com/parts/MOR-23020/
And here is the stud kit that I am using:
http://www.summitracing.com/parts/ARP-234-5601/
fla1976 11-23-2009 01:21 PM
Call the tech line listed on this site:
http://www.moroso.com/support/tech_support.asp
jrsmith80 11-23-2009 01:46 PM
I got it figured out, apparently ARP only sends out 5 studs with standoffs in their stud kit, which in turn will not work with the windage tray that I have. Kind of a joke, but I was told by a lady that if I needed another bolt then I would have to purchase one. It would be noice if that was stated in the description when ordering.
kwkracing 11-23-2009 05:09 PM
The last hole in the windage tray uses the oil pump stud or bolt and not one of the long studs that would have came with a arp stud kit???
