-   -   Th400 or Poweglide ? (https://www.racingjunk.com/forums/showthread.php?t=26467)
Robsinno 11-24-2009 11:58 PM
I've been going round for round on this decision as my research so far has not convinced me to lean in either direction. Are there any experienced builders or racers out there that can offer some first hand knowledge about this topic? Most comparisons I see ask about car weight and HP/Torque. This is a pro-street car that is driven short distances on occassion for car cruises, etc (approx. 300mi/yr). Here is the relavant information about my car.
68 Firebird
3300 lbs w/driver
474 stroker Pontiac
742 crank HP & 672 ftlb torque
Th350 trans w/4500 stall - NO Trans-Brake
3.73 rear gear
28" x 10" slick
Currently runs 9.90s at 136mph....1.42 @ 60'
I want to change the Th350 because I intend to start using Nitrous, which will put me at about 1000HP total (more than I want to trust my TH350 to handle), and I would like to install a trans-brake.
Thanks,
Bob
CamBirdRacing 11-25-2009 10:30 AM
400
cepx111 11-25-2009 10:39 PM
You wont catch me saying this too often, but for your app, TH400
kbartley 11-26-2009 03:38 PM
glide or 400
x3
Robsinno 12-10-2009 01:26 PM
What is an X3 ?
Robsinno 12-10-2009 01:35 PM
Need more input please
Thanks for your feedback, but can you explain why you would pick the Th400 over the glide for my application?
Thanks
TheYellaBrick 12-10-2009 02:37 PM
3 gears forward as opposed to 2 gears forward...better for street use even if only occasionally.
russ67chevelle 01-03-2010 09:49 PM
also a stock powerglide case wont be as strong. funner to drive th400...my vote and heart is with the turbo 400!!!
RonOwensRacing 01-04-2010 06:44 AM
400 Turbo also with the NOS you will kill that 350.
chevyfireball 01-13-2010 12:52 AM
I ran a TH400 in my Camaro. It was race built but I did manage to f*&k it with around 1000hp.
I was using a transbrake and 3800 stall converter.
It would be better than a glide for your application but don't go doing burnouts starting in 1st gear.
