-   -   68 Firebird disc brakes. (https://www.racingjunk.com/forums/showthread.php?t=26548)
hotrod1024 12-02-2009 04:20 PM
Can anyone tell me what other cars might have disc brakes on front that will fit my 68 Firebird.I know Camaro are the same,but with budget was hoping something else might interchange that I could get from a salvage yard,or put together.Mine has drums all the way around now.Just wanting disc for front.Thanks,Randy.
mytmouz 12-02-2009 07:29 PM
69 to 74 Nova's...
hotrod1024 12-04-2009 07:13 AM
Thanks that helps.Is that all that will interchange?I might find some other 73-74 local salvage.Im gonna check this weekend.
cam67152 12-04-2009 08:23 PM
There are a number of different cars that will work, you may also need to change your spindels, for what there worth you would be better off buying new from one of the many aftermarket suppliers, there cheap, new and they will WORK!
But here is a list if you decide to go with used.
NOTE: Section 2 fits Section 1 by including the backing plate.
NOTE: One-piece design was original equipment for vehicles in Section 1; two-piece design was original equipment for vehicles under Section 2.
Section 1
Buick Special '71 (one-piece)
Buick Special '72
Firebird '69
Grand Prix '69-'72
Old F85 '70-72
Tempest '69-72
Section 2
Apollo '73-74
Buick Special '67-70 and ('71 two-piece)
Camaro '67-69
Chevelle '67-72
Chevy II '67
Firebird '67-68
Monte Carlo '70-72
Nova '68-72
Olds F85 '67-69
Omega '73-74
Sprint (GMC) '71-72
Tempest '67-68
Ventura II '71-74
Good luck, CAM67152
hotrod1024 12-05-2009 06:32 AM
Thanks guy,that helps alot.
