-   -   Carter 850 Thermoquad question (https://www.racingjunk.com/forums/showthread.php?t=26668)
markdunlap 12-13-2009 09:18 AM
I would like help on info about rebuild parts for a Carter 850 Thermoquad.
The carb ID is 4846S. Really just need to replace the accelerater pump, but rebuild kit part numbers and source would be helpful too.
I believe this is an aftermarket carb and not an OEM application?
It is on a 455 Buick engine now. Worked great before the pump messed up.
TopspeedLowet 12-13-2009 09:43 AM
Just like a Quadrajet basically, just plastic
That thermo quad is an old chrysler piece that came on the ole trusty 360 4 bbl Cordoba in the mid 70's, say 1976. You should be able to find a kit for it with that info at you local parts store.
Bruce
cepx111 12-14-2009 10:46 PM
I believe they came on more cars than a 76 Cordova :shock:
Thermoquads were used as original equipment on mostly Chyrsler products from 1971 to 1985.
A few Lincoln 460 CID engines in 1974 used an electric choke version of the TQ. IHC used TQ's from 1974-1980. Australian Fords also used these carbs in the late 70's and early 80's.
The carb was also produced in aftermarket versions up to 1000 cfm.
Your carb is a aftermarket competetion carb.
I looked and looked for a kit, thinking yours maybe the same as a AFB 900 series 850 cfm carb made by carter, not sure though, dont quote me.
To make sure call Carter......
Carter tech line 1-800-325-8886
Goodluck, Cp
DRTRCR22 12-15-2009 08:33 AM
Kits on eBay right now... 12-15-09
http://cgi.ebay.com/ebaymotors/Carb-...item20ae8c7572
http://cgi.ebay.com/ebaymotors/1978-...item3ca86db91f
mopar1968 12-17-2009 08:25 PM
It doesn't matter if it is aftermarket or oem, The pump is the same size, Should be able to pickup a pump at local parts store :!: :!:
''JUST MY TWO CENT'S WORTH''
sgtfury67 01-17-2010 04:25 PM
thermo quad
Any good carb rebuilder will have any parts you need, if you replace the pump make sure you replace the plastic tube from the pump to the squirter. Mopar started using the thermo quad in 1970 on 340's and 440's.
mopar1968 01-17-2010 05:59 PM
This carb was used on 318 police packages, Dodge diplomat, Plymouth st Regis Police packages, Gran fury Police packages, 340,400,440 All after 1972, Thermoquad started emissions with chrysler, Was used on all lean burn systems Mancini racing has any part for these carbs you will need :!: :!:
