-   -   BURN OUT IN A DRAGSTER (https://www.racingjunk.com/forums/showthread.php?t=26755)
bigray 12-19-2009 10:35 PM
This question is just because i dont know ?? when you do a burn out in a dragster with a power glide,is it done in 1st gear or high gear ? i would surely Bet High gear,,but sometimes you just gotta ask..
johnracer 12-20-2009 02:50 AM
When I had my FED, I did'em in high. In fact, I've done high gear only burnouts in every racecar I've owned.....from an 11 second doorcar to my current 8 second Vette roadster. IMO, most cars that run 12 seconds or quicker could do high gear burnouts......
Johnny
THERATTLER 12-20-2009 04:16 AM
high gear only , never start it in low and then shift , asking for trouble,,I always roll through the water and hit it while car is still rolling , :D
shawnp 12-20-2009 04:46 AM
Make sure you got a good wet tire, stick it in high gear and have it 8)
slowmotion 12-20-2009 05:21 AM
High gear in the altered.
bigray 12-20-2009 07:27 AM
thanks for the info.i was pretty sure it was high gear.and to never shift.in the burn out.but man do i see alot of racers do it.but everybody has there own way.
shawnp 12-20-2009 04:00 PM
Sometimes a guy that does not use a 3-step that feathers thru a burn out sounds like they are shifting in the water as they snap the throttle to get the tire spinning and then come down to their burnout RPM.
3dracing 12-21-2009 07:11 AM
High gear a 6000 chip and let it eat.
hammertime 12-21-2009 07:23 AM
high gear for sure a 3 step is the best way IMO hoosiers 6200 goodyears 6500
