Converting Camaro back to Rally Sport
my car was originally a Rally Sport so I bought the grille kit and started mocking her up...
original view http://static.racingjunk.com/63/ui/9...475269-427.jpg teardown http://static.racingjunk.com/63/ui/2...475322-757.jpg mockup http://static.racingjunk.com/63/ui/5...475315-355.jpg teadown again to install valance http://static.racingjunk.com/63/ui/9...475329-807.jpg valance installed now off to the bodyshop! http://static.racingjunk.com/63/ui/4...475364-438.jpg |
I would remove that fan, its a major air block at all speeds
with a 498" big block, she needs all the air movement (artifically supplied) she can get! :D
Thats fine if you dont drive the car over 15 mph, the faster you go the less air you push throu a fan like that, it acts like a big 14" plate once your mph gets higher than the cfm the fan pulls on it own, air looks for the least restrictive path and goes over the car instead of threw the radiator. Just a lil tip incase u run into a problem later.
If it works, then thats awesome! Your car looks really nice! Good job. |
after a 2 weeks getting ready, 3 1/2 weeks at the bodyshop getting a lot more done than originally expected the bitch is back and all put together. All I have left to do is install the QA1 front coilover shock kit and new sway bar. Come on spring!!!!
http://static.racingjunk.com/63/ui/0...133930-280.jpg http://static.racingjunk.com/63/ui/4...134154-864.jpg |
:shock: :shock: :D :D :D :D :D Pretty In RED !!
:mrgreen: LOOKS GOOD!!!
LOOKIN' REAL GOOD :!:
Did you do the rear as well? X2 on SPRING :D |
LOOKIN SWEEET...... 8)
Lookin' good harbone. I can't believe you want to get rid of it.
| All times are GMT -8. The time now is 04:36 PM. |
