-   -   question about nos solenoids (https://www.racingjunk.com/forums/showthread.php?t=26787)
bowhay 12-23-2009 09:30 AM
i have a cheater plate but i need to get new noids
do i have to run the cheater noids or can u use say powershot or super powershot noids
i know the orifice is defferent and ive heard it will change the size of the shot
is this true....im new to the hole nitrous thing and any advice would be appreciated
bbchevy 12-23-2009 01:47 PM
Plate
You can run ANY Noid you want!The Noid has a Limit of what it will Flow,as the Plate?
Later
G 8)
chevyfireball 01-11-2010 01:49 PM
I had a 400 powershot plate system on my Camaro. It came with Cheater solenoids for the fuel.
rick329c 02-01-2010 12:57 PM
NOS
You can run any solinoid you want but the bigger the orfice on the solinoid the more it will change your tune up so be careful.
I had a Top Sportsman Car that I used to brag I only shot with 200HP jets, however i had the big NOS brand bottom exit Nitrous solinoid on it and it does make a big difference.
blaktrukpilot 05-06-2010 07:36 PM
nitrous solenoids
How often do you need to rebuild them?
Tod74 05-06-2010 10:15 PM
Re: question about nos solenoids
My advice is to use the parts that NOS put together as a kit and follow their instructions for the tune up. Someone who is familiar with Nitrous mixing matching things is different than a beginner swapping stuff around. Just my opinion.
