HOW MUCH NITROUS
HOW MUCH NITROUS CAN I USE IN MY MOTOR,IT IS NOT A NITROUS MOTOR,BUT I HAVE A EAGLE FORGED ROTATING ASSEMBLY.CAM IS 260/264@50 674 EXH./688 INT.LSA 111 PLUS 4,INTAKE CENTERLINE 107.
Re: HOW MUCH NITROUS
I would put a 400 shot fogger system on it :!: :!:
''JUST MY TWO CENT'S WORTH'' |
what brand pistons?
if pistons can handle, then last question would be what rings, and are they gapped for spray
btw, dont mind the mopar lover his mind thinks a lil sideways :roll: |
quote]
GAPPED FOR NITROUS,DO YOU MEAN HOW FAR THE TOP RING IS AWAY FROM THE TOP OF THE PISTON?[/quote] No, he is speaking of the gap between the butt ends of the ring. Dave |
With forged internals your safe to around 250 shot, just make sure you pull timing out accordingly.
Rule of thumb 2/3 degrees for every 50 hp of nitrous. The MSD digital 6al has a built in single step retard you can use just for nitrous. Slap a 150 plate on it, program the single step retard (6 degrees) to be ativated with the nitrous on and your good to go. Goodluck, Cp |
a big block on nitrous is a beeeeautiful thing
| All times are GMT -8. The time now is 11:40 AM. |
