-   -   Bead Lock Wheels (https://www.racingjunk.com/forums/showthread.php?t=26795)
jreiley 12-24-2009 07:22 AM
Bead Lock Wheels
I see lots of cars now running with bead locks and I wonder if they really need them. Fuel cars, no doubt, but your everyday bracket car, well I have my doubts. My question is do I need to put bead locks on my car, a 3000lb car with somewhere around 1000hp?
chevyfireball 01-14-2010 01:54 AM
I run 6.8 sec quarters at 198mph and use rim screws. Bead locks look cool, cost a hellova lot and are really only needed over 200 mph.
hammertime 01-14-2010 05:35 AM
I can tell you why most put them on bracket cars ... they are more consistent, its been proven several times.
jreiley 01-17-2010 05:00 AM
So would you use double or single bead locks?
kod99 01-17-2010 05:27 AM
I was wondering how bead locks are more consistent? I use rims screws and the tires do not move on the rims. If they did, I would see it in the bead being torn by the movement of the screws.
Is it the extra mass of the lock rings being so far from the center point of the axle?
hammertime 01-17-2010 05:47 AM
Less sidewall movement not tire movement on the rim ....
But of course this is to a point if you dont have the power to lug the extra weight your just wasting your time, but by all means if you got the HP the beadlock is the ticket ..
SST4530 01-18-2010 04:50 PM
I thought about the bead locks for my wheels, but decided since the locks add about 8 lbs per wheel there was no performance gain by using them. It's been said every 10 lb of rotational weight is equal to 100lbs of sprung weight. So thats like adding 160 lb. to your car. Locks do look cool though! :wink:
hammertime 01-19-2010 05:03 AM
3 thousands difference back to back weld beadlock vs nonbeadlock same hoosier tire :)
SST4530 02-10-2010 11:00 PM
Can't argue with that. May be a bigger difference a SB than a BB?? :?
hammertime 02-11-2010 04:29 AM
I have no doubt if you dont have the HP/TQ to lug the added weight along they will be much slower. Them bad boys are heavy !
