-   -   ladder bar help (https://www.racingjunk.com/forums/showthread.php?t=26804)
mikesramblur 12-26-2009 04:22 AM
ladder bar help
this has been a very long ongoing project getting this rearend done. i finally got it installed yesterday. its a ladderbar coil over suspension conversion on a leafspring car.
so, its all in tires on sitting on the ground. i leaned on the side of the car and the body shifted wayyyy over the rearend, i can shake the car from side to side about 2" either way. is there supposed to be a panhard bar in a ladderbar/4 link suspension ? also, i'm not liking the way the rear of the car hangs so low, but thats another problem for later.
oldandtired 12-26-2009 05:18 AM
You need a track locator or panhard bar. The track locator bar is for drag race only vehicels.
Dave
cam67152 12-26-2009 08:24 AM
yea, you need a diagonal link, wishbone locator, or a panhard bar.
cam67152
TheYellaBrick 12-26-2009 09:11 AM
If you go with a panhard bar, make it as long as room allows so that you get the LEAST amount of suspension travel 'arc' -( side to side action as the suspension goes through it's travel.)
mikesramblur 12-26-2009 12:21 PM
alright then. thanks for in the info. i'll be looking for a panhard bar.
zipper06 12-26-2009 03:56 PM
Here you go, several different types to choose from. I'm useing a bolt on diagional.
http://www.cachassisworks.com/Attach...AC/CAC9973.pdf
promod45 12-26-2009 04:10 PM
ladder bar
i dont recomend a diaginal bar in any car i build i always use a wishbone and the reason is that if you raise or lower your car once the diaginal bar is installed the body will move to the right or left and with the wishbone it stays the same no mater how much you lift or lower it..
mikesramblur 12-27-2009 03:54 AM
is this the diagonal link you guys are talking about?
http://i87.photobucket.com/albums/k1...amc/car003.jpg
if so its not stopping body movement on my car.
mikesramblur 12-27-2009 03:57 AM
anyone have pics of a panhard bar installed, just want an idea of location on frame to where on the axle.
zipper06 12-27-2009 05:56 AM
That's the type i have on my prostreet 98 Sonoma,do you have your's bolted to the bottom bracket bar on the ladder bar? if so you shouldn't have more than a 1/2" side movement with everything tightened up. My malibu has a welded on type, but it's a 4 link car.
But i agree with Promod 45, the wishbone is the absolute best setup. I personally wouldn't use a panard bar if it's a drag car, if it's a street car then the panard will work fine.
Below is some pics. of a panard bar installations from art Morrison.
http://www.artmorrison.com/2006cat/37.pdf
