-   -   mixture screws (https://www.racingjunk.com/forums/showthread.php?t=26866)
supersmurf666 12-31-2009 04:27 PM
mixture screws
trying to adjust my friends edelebrock 600 carb and doesnt make a difference how far in or out i turn them has no effect on idle.I just cant remember what the problem is.help!!!!
suicidebomb 12-31-2009 06:13 PM
At an idle can you turn them all the way in till they seat, and the motor continues to run? Call me curious.
lively 12-31-2009 06:37 PM
AIR/ VACUUM LEAK :? :? :?
oldandtired 01-01-2010 05:21 AM
x2
hammertime 01-01-2010 06:28 AM
x2
x3
supersmurf666 01-01-2010 06:34 AM
no vacum leaks.and yes turned all the way in and it still runs.I read about that in one of my hot rod books so i guess ill start looking through them so i can find that article and see what the problem is.
TS1955 01-01-2010 07:52 AM
If your idle screw on your throttle arm has the throttle plates opened past the idle transfer slots, then your mixture screws won't have an effect when adjusted. Something you might look at!
TS1955
suicidebomb 01-01-2010 11:09 AM
Check what TS said, if that's not the problem, the idle mixture screw seats, are ruptured. Probably time for a new carb. I don't know of any way to fix that.
MEMRACING62 01-01-2010 11:20 AM
X3 TS
supersmurf666 01-01-2010 01:16 PM
ok.thats what i was thinking but couldnt remember.Thanks for all ya'll's help.HAPPY NEW YEAR!!!!!!!!
