th 350 problems
I have a th 350 and finished install last night drove great went to drive today goes into gear but only moves at higher rpm could this be a bad oil pump? any advice is great thanks.
Are you sure the convertor was all the way in the tranny when you installed last nite? Did it function properly then? Is it stock?
Dump in enough Trany Fluid ?
Yes converter is all the way in and yes it is bolted. yes it worked perfict than didnt work. yes stock converter. and yes plenty of fluid
| All times are GMT -8. The time now is 02:52 AM. |
