-   -   blown bbc using dry sump (https://www.racingjunk.com/forums/showthread.php?t=26899)
prince 01-03-2010 06:24 PM
have a bbc carberator motor that uses a dry sump system.i am converting to blown. how does the belt drive hook up with blower pulley in the way? i was driving the pump with a belt off the end of crank. thanks any suggestions?
sc4405 01-04-2010 05:16 PM
One way I have seen it done is to sandwich the dry sump pump between the cam drive hub and the fuel pump. Kinda puts the fuel pump way out there but the one I saw ran like a bat outa' hell! I believe RCD or maybe Waterman makes adapters for this purpose. I can give ya a name of a racer in California who will know....... 8) JB
THERATTLER 01-04-2010 08:29 PM
[img]http://img706.imageshack.us/img706/5...cae91kxrca.jpghttp://img706.imageshack.us/img706/r....jpg/1/w77.png[/img]
here you go,,,available from RCD engineering
