dragster body
how many places should a dragster body be attached to chassis
building new dragster ---need some ideas --some pics would help thanks |
A aluminum panel body or a fiberglass one piece body?
dragster body
FIBERGLASS BODY
If it's fiberglass, attachment points should be minimal.Take a look at a M&M car with the Reageal fiberglass body. They mount the body down from the shoulder hoop and once on each side of the front. Some guy's then tie them together under the bottom rails of the car not attatching to the chassis. The body needs to flex independantly of the chassis, or you will crack it up
Look at M&M Racecar website Thanks Mike |
A lot of the times there is only 6 in one peice deals along the bottom, like mentoined above there is usually a floating tab with a bar across to the other side that sits there letting it flex and move a bit on a few of them.
| All times are GMT -8. The time now is 03:06 PM. |
