-   -   Swapping from mineral to synthetic oil (https://www.racingjunk.com/forums/showthread.php?t=26916)
prozb 01-05-2010 01:23 PM
Has anyone swapped from a 50 weight mineral oil to a 40 weight synthetic and seen any performance gains? I will be swapping from a 15w50 mineral to a 10w40 synthetic in my 582 BBC. Just thought i would ask the question, i have always used a 50 weight mineral in all my engines and have been told numerous times to switch to the synthetic for the frictional benefit and free HP gain. Was told around 10-15 at 7500rpm was typical.
TheYellaBrick 01-05-2010 03:07 PM
We use REDLINE front to rear as we are dealing with MAJOR heat buildup when it's 100+ degrees out and the engine is spinning 6,000+ for 50 to 100 miles.
As an example of reduced friction, way back when I was into aircooled VW's and living in Denver, I filled up the transaxle with AMZOIL in the fall and as the temps dropped, I would experience only a 20 RPM drop after I'd start the engine and put it in neutral and let the clutch out. With mineral gearlube I would get a 1,000 RPM drop. :shock:
