fuel cell size?
what size fuel cell are you guys running?I have a 69 nova with a 565.I will be running quater mile.Thanks Art
I am getting a 93 Mustang GT that has a 12 gallon fuel cell in it that will be runnin the 1/8mi and 1/4mi
I'm using a 32 gallon Fuel Safe MilSpec bladder and can system. HOWEVER I run a whole string of quarter miles at a time !
Don't mind me, all this c-c-c-c-cold weather has done frosted my brains and I'm bored st-st-stiff. :roll: :roll: |
I have a 4 gallon cell in mine and it's plenty.....
I run a 3 gal. on alcohol in the Malibu. I originally bought a 4 gal. but couldn't get it to fit next to the rad. frame and front fender well. If you're running gas 3 gal. will be big enough, but alcohol in the qtr. it's cutting it close, you'll probably use 1 1/2 to 2 gal. alcohol but less on gas if you drive it to the starting line and back to the pits after the run.
JMO Zip. |
I'm running a 540 BBC on gas and I use 1 gal per pass. I drive it to the lanes and back to my pit. I have a 10 gal cell only because that's what was in the car when I bought it. Depends where you are putting it and how much space you have and do you need it for weight transfer. A 5 gal cell would be plenty in most cases.
I run a 2 gallon front mounted custom tank next to radiator. Plenty enough on race gas!!!!
Thanks for all the replies .I was thinking five gallon now I know for sure that its plenty big enough.Thanks again Art
I have a 3 gallon cell :!: :!:
''JUST MY TWO CENT'S WORTH'' |
12 gallon in a tube car for cruise ins... :D
| All times are GMT -8. The time now is 11:35 AM. |
