-   -   Check your equipment (https://www.racingjunk.com/forums/showthread.php?t=26933)
slowmotion 01-07-2010 06:06 PM
Now's a good time to check your equipment to make sure it's all up to date. Make sure your SFI's are current for your sanctioning body. It would suck to find out at the first race when you fail tech.
I need to take the belts out of mine and get them rewebbed. I need to give the car a general check of all the nuts and bolts.
I might reletter the car. I haven't decided for sure on that one.
TheYellaBrick 01-07-2010 06:50 PM
For those who need re-webbing, M&R does that service. I have mine done every 3 years whether I've used them or not.
http://www.mrproducts.com/
mooneye777 01-07-2010 09:54 PM
One thing that probably everyone over looks, as I have never checked before but do now. On my old dragster I had just made my second pass of the day. I parked in the pits, a couple minutes later my wife said hey your car is very lightly smoking around the right side rear brake, I figured, YA its probably hot. So i looked to please her mostly as she does not like me driving that fast anyway,. And one of the bolts holding the brake disc to the hub had backed out. It had sawed through the aluminum caliper mounting bracket, no joke only 1/32 of an inch was all that was left hohling the caliper on the rear end housing. Had She not seen that my next pass would have been a total catostrofic failure in my 8.90 super comp car. It would have ripped that caliper off and at about 157 mph, AAAAHHHHHHH NO FU_ _ _ _G Brakes !
So everyone please check your brake mounting gear also.
mooneye777 01-07-2010 09:56 PM
What do they typically charge to reweb a belt?
TheYellaBrick 01-08-2010 02:48 PM
It depends on make and latch type. Drop them an email for pricing.
bad60gmc 01-08-2010 03:14 PM
I had that happen on a custom chopper, I thought i had a brake caliper sticking and rode it 10 miles home. When i pulled in the garage on the smooth concrete the rear wheel locked up. The bolt stuck in the alum caliper bracket. that was a close one!
