-   -   Pro Comp ignition (https://www.racingjunk.com/forums/showthread.php?t=26939)
Sox 01-08-2010 12:21 PM
Pro Comp ignition
Has anybody run this Pro Comp Ignition system.They claim to be as good as MSD.Before I buy the complete setup I would like to know if anyone has run them..
gungho 01-09-2010 01:21 PM
Oh boy,hang on!!!
MEMRACING62 01-09-2010 01:34 PM
Im sure someone will say they heard from the friend of a fouth cosin that once had a friend that heard from sombody that there bad. :roll: :roll: :roll: BUT HAS NEVER ACTUALLY USED ONE THEMSELVES :shock: :shock:
RonOwensRacing 01-09-2010 09:46 PM
I have sold at least 100 of them and i have had 6 that had problems 2 with the distributors 3 boxes and 1 coil and i know for sure 1 was the customers fault because when he sent the kit back to me and i looked at it the wire's going into the box was melted the others i don't know i just replaced them for the customers.
I don't think there bad for the money .
Now there is another kit called a mega fire kit that is a killer kit put's out about 20% more spark than the MSD 6 al box . well that is what they say anyway i have sold so far 62 unit's and not one back and all of the local guy's that have them are very happy with them cost a little more but not a lot.
Hope this helps some.
rabiddawg 01-10-2010 06:35 AM
thanks but ill stay far away from anything that says procomp.
TYSON14 01-11-2010 04:13 AM
went threw 2 pro comp water pumps and 2 pro comp boxes.......finally went with msd.....but the heads work fine........but now our car want turn past 6000rpm....it seem like a rev limiter come on....sometimes it want start and somtimes it runs fine but if you put a timing light it is jumping around ....went with a msd 6al box and called msd they said the boxes dont have shorts in them..... it is the distributor
mytmouz 01-11-2010 08:50 AM
I have dealt with 2 Pro Comp distributors belonging to acquaintences, both would not fire, new ou of the box. Funny though, the ones they sent back to then did...
gungho 01-12-2010 01:42 PM
Do you race that camaro?or is it a trailer queen? :D :D
sgtfury67 01-17-2010 04:50 PM
procomp distributor
The early procomp stuff was very inconsistant, it has gotten better though. I've had MSD problems many times and won't use one again
