67 Camaro coil over shocks for the front suspension
I have a big block 67 Camaro that I want to take the front shocks and stock front springs off and replace with a set of coilover adjustable shocks. the front suspension is all stock except the spindles and wilwood brakes. want to be able to adjust my ride heigth so I can lower it at the track and bring it up for the street, any suggestions for a good manufacturer?
Thanks |
I have Qa1 on my 72 nova and I am getting ready to order a set for my 70. They are 450 but very nice and adjustable. You can also adjust ride height with a spanner wrench.
Hope this helps... |
X2 on the QA1's there a snap to install and there is lots of ride height adjustment. They have a few different options, drag, street, single or double adj. I have them on my 67 street car and on my 67 drag car,
well worth the money. cam67152 |
thanks guys! the qa1's were the best I have seen on the net and other forums, just curious, how much actual heigth adjustment do you guys have??
without looking at the car I think it was about 3" total of threads. its been awhile since i put them on though...
thanks Josh!
I put a set of QA1 adjustables on my 69 Camaro. Fitted perfect.
A wise investment is the coil over thrust bearing kit that goes between the spring and pad. Much easier to turn the big nut.
$30 per pair from Speedway $40 per pair form SW Race Cars Dave |
so far I have price shopped everybody and Autofab has the best price. Plus their receptionist was the nicest lady in the world and Josh the parts guy is a tru professional. $467.00 for the kit with the thrust washers and wrenches plus $15.00 in freight, gonna order them up today!
Chris,
You do realize that you'll need to adjust the toe every time you change ride height unless you have zero bump steer ? |
| All times are GMT -8. The time now is 07:38 PM. |
