-   -   s10 tranny problems (https://www.racingjunk.com/forums/showthread.php?t=26960)
s10Travis 01-11-2010 03:28 PM
s10 tranny problems
I have a 88 chevy s-10 with a th350 a 350 engine and a 8.75 rear end since i have put the rear end in i have busted the bellhousing off 2 tranys and busted the bellhousing and tailshaft off 1.any suggestions?
Drtmod5 01-11-2010 03:40 PM
What type of mounts are you using on motor? Trans? Solid mounts? Need more info on your current setup.
spib 01-11-2010 04:10 PM
have heard people have this problem when they run a solid tranny mount, or only a front plate with no mid plate and solid tranny mount, or sometimes no mid plate and lots of hp
s10Travis 01-11-2010 04:18 PM
i have a front plate and a urathane trans mount
Drtmod5 01-11-2010 04:36 PM
I don't think that's enough. Too much hanging weight between the two mounting spots. You need a midplate, but don't go solid on the trans. Big trouble there! JMO
s10Travis 01-11-2010 04:39 PM
ok thank you very much i give it a try
mytmouz 01-11-2010 05:00 PM
Did you do anything to the driveshaft when you swapped rear ends? If not, the driveshaft is too long...
MEMRACING62 01-11-2010 05:43 PM
X2, I would look a drive shaft length if your breaking tailshaft housings
s10Travis 01-11-2010 07:05 PM
we had to build a drive shaft it has i think like 3/4 of a inch play
Drtmod5 01-12-2010 12:54 PM
Who did the work on the driveshaft and was it balanced?
