-   -   Coil over shocks (https://www.racingjunk.com/forums/showthread.php?t=27023)
ssym 01-16-2010 04:08 PM
Coil over shocks
Looking for opinions on rear coil overs.
60% street/40% strip Chevy II w/4-link. I have non adjustable AVO's now with one leaking.
Single adjustable or Double? Double would have to wait a couple more weeks for the extra money.
QA1, Strange, or Vari Shock?
Bearing or Poly? Set up for poly now. Would I have to reweld the tabs for the narrower bearings?
Are new springs recommended with new shocks?
Thanks again for your help.
Steve
chevyfireball 01-19-2010 02:17 AM
QA1 were great on my Camaro.
ssym 01-19-2010 03:27 AM
Fireball, what shocks do you run in that monster Nova?
BEAST477 01-19-2010 03:01 PM
QA1 or Strange are both good choices. You will have more interior noise with the bearings over the poly as far as road and suspension noise goes. If you choose the bearing you can make spacers to make up the difference in mounting. Your springs should be fine as long as you use the same length shocks. Hope this helps.
promod45 01-19-2010 03:49 PM
shocks
check out the shocks chassis works sells, there a very good shock and there very easy to adjust, there called Varishock
mopar1968 01-19-2010 07:01 PM
I have QA1 on mine :!: :!:
''JUST MY TWO CENT'S WORTH''
TS1955 01-20-2010 01:42 PM
I've been running Koni double adjustable shocks and have had pretty good luck with them. JMO
TS1955
