-   -   Eliminating wheel hop (https://www.racingjunk.com/forums/showthread.php?t=27109)
nemesisracing 01-23-2010 04:59 PM
I have a 2007 Mustang GT. I have some mild power adders to the engine and run a 4.33 gear ratio. The car still has all stock suspension, as well as the original stock pirelli tires. It has always had a bad problem with wheel hop even before the engine mods and gears were installed. I was thinking of ordering a set of adjustable upper and lower control arms, but wanted to get some advice before I spend nearly $400. Do you guys think this would be a wise choice or is there something else that you would recommend? Any information would be greatly appreciated!
JEFF69Z28 01-24-2010 06:22 AM
YOU HAVE CHOSEN WISELY!
