sbc
hey guys i just was wondering if anyone was racing with a 383 sbc and what you guys was shifting the engine at. i was talking to a friend and he said he was shifting around 7200 and 7300 with his 383 i have never shifted my 383 over 6800. let me know what you guys shift at thanks mack.
Well i run a small block Mopar and i shift it @ 7400 rpm all day long :!: :!:
''JUST MY TWO CENT'S WORTH'' |
can't wait for the track to open and try shifting it at 7200 or ????, car went 11.07 shifting @ 6800 rpm, hope to get it in the 10's this year.
What do you have for a cam and heads? That'll determine where you should shift.......
the heads are pro actions 235 208 int 160 exh the cam is comp 630-630 solid roller, but i also have a comp 675-645 solid roller which one would you go with. oh yea the trans is p/g 1.76 ford 9" with 4.71 gears 28x10.5x15's m/t slicks. in a 87 camaro around 3200 pounds.
@ 3200lbs i'd stay with the cam you have in it .630/.630 for the low end torque.
JMO Zip. |
thanks for the replys guys and good luck this year and be safe.
hey bigmack how are your 60 foot times with your combo.
it's in the low 1.5's hope to get it down in the 1.4's this year
| All times are GMT -8. The time now is 03:52 PM. |
