Valve lash cold/hot
I have a new to me 582 -- the builder says valve lash is .016 hot. My question is...
I am changing the lifters= I have a Jesel setup-- so i have to remove the assembly... now when i put it togther i want to lash it somewhat close being cold.. as i cant start it yet ..im waiting on some odds and ends but i would like to have it close.. What should i set the lash at cold if the builder has said 016 hot? Thanks In advance Keith |
Question, does it have aluminum or cast iron heads?
Close is about all your gonna get till you can figure out just how much growth your dealing with. I would to set them all on .011 to 010 cold. Start it, let it get good & warm, re-set them 'hot' let it cool, check again. Make note of the lash 'cold' - then you you can set them 'cold' all the time. On my motor, BBC 496 W/ cast iron heads. I set all mine @ .022 cold, calls for 28 and 30 hot, never had any issues. Cp |
lash
I am a knucklehead... the lash number is 026 hot... i dont know where i got 016...sorry
The are Dart 360 aluminum heads . Thanks Keith |
set them at 23-24
Mine I set cold at 23 and they are 25 hot alum heads |
I set mine at .016 cold and they are around .021-.022 hot. Iron block aluminum heads. BBC.
I sure hope this doesn't turn into another 'valve lash' thread.LMAO
Tell me EXACTLY how to adjust my valve lash. :lol: |
Mine are .26/.26 @ op. temp. Sorry guys, but you know I am learning too, so here is what I do not get: If metal EXPANDS when hot, why is the lash LESS cold? If metal expands, should you allow for more LESS lash when cold? I don't get that!! Should the heat provide less tolerance in itself? For this confusion/reason, I never set mine cold. Until I understand this, I will not take a chance.
Wish I could help you here scooter, But i've been setting my lash, the WRONG way, for forty years.
| All times are GMT -8. The time now is 03:46 AM. |
