Solid cooler line
Can I run a solid steel cooler line in my Glide? Of course I can, but is it safe? Does NHRA rules allow it?
As in steel OEM type line?
Or are you trying to block off flow by looping it with a solid line? I wouldn't recommend the latter. The transmission needs a cooler no matter what you think or what somebody else has told you. JMO, Cp |
| All times are GMT -8. The time now is 10:48 AM. |
