main stud girdle
just wondering if anyone can tell me how much the main stud girdle adds in strength and how much more HP you can add to a two bolt 454 block if you put one on the mains, thanks
Anytime you can tie everything together it will strenghten the integrity of an engine, how much 'more' HP you can throw at it is debateable though.
It certainly would be stronger with one than without IMO. I bought one and planned on using it on my 454 2 bolt block but I ran into fitment issues with the oil pan, after purchasing three different pans that would not clear the guirdle, I ditched it. I would say 750- to 800 HP is about the point where you'd want to start thinking about getting a aftermarket block, stud guirdle or not. Goodluck, Cp |
girdle
thanks cepx111 i dont plan on using it it is a pain in the butt to use as you said
| All times are GMT -8. The time now is 04:49 AM. |
