pro comp shaft rockers
Have any used Pro comp Shaft Rockers? I found them on line and they look like a good deal.
A guy on speedtalk.com posted pictures of his small block chevy shaft rockers by Procomp...they came apart..not pretty. Might go over there and look up user "af2" .He is the one who posted the pics.
I'm sure every brand has failures though. |
Don't waste your time. They are prone to letting the needle bearings loose, the hardware is brittle and the finish machining is unsatisfactory. I'd rather run a used set of long slots than the pro comp shafts.
i had a set,they don't fit and don't come with any shims.
| All times are GMT -8. The time now is 11:54 PM. |
