427 tall deck
I am starting to look around for a BBC 427 tall deck truck motor to use for my spare setup.
The crank and block is what I want. What years had forged cranks and 4 bolt main? thanks,,,,,,,,,,,,,,,, |
This site list the casting #'s for the 4 bolt main blocks, i think all the 4 bolt main truck blocks had a steel crank but not sure..
Zip. http://wildmusclecars.com/muscle-car...sting-numbers/ |
anyone know if all tall deck 427s had forged cranks?
427 tall deck
All 366 - 427 truck tall deck blocks had 5140 forged cranks for heavy duty use in 2 ton trucks.
These are not as strong as current 4340 forged cranks however. And they are 20? years old before you get to them. The real value of a tall deck block for bracket racing is to use a 4.250" srtoker crank and make a 496. Also the free 4 bolt mains. Remember they cause header clearance issues in stock chassis cars and aftermarket heads with raised exhaust ports make it more so. |
Do 366 blocks use the same block core?
can they be bored to 4.310? |
427 tall deck
Leave the 366's in the junk yard. Only thing that is of use is the crank. Core size is smaller than 427.
Re: 427 tall deck
Dave |
| All times are GMT -8. The time now is 08:44 AM. |
