regulator
I was told by a company that I just got a regulator from to not mount regulator, just plumb in line, up close to carb
he said vibrations when you mount a regulator will kill them agree or disagree ? my set up is single carb, 8an line 600 hp motor, no return line |
I mounted mine on the old car and never had a problem. Im trying to find a good spot right now to mount it on the new car but havent found the right spot yet.
Whos regulator did you get? If its a BG 4 port, place a lock washer under the mounting bracket bolts if you use it as the supplied bolts are too long and doesnt squish the diaphram down tight. It will leak. I speak from experiance on this one. I called BG last time and they told me they never seen that before and now 4 years later I buy a new one and see the same thing. Craig |
Its a moddified holley I believe from pro systems carb, looks like my small reg I got with my blue pump but it uses 1/2 inch in and out
http://www.prosystemsracing.com/cata...92/5339867.htm |
Mine is mounted on the firewall, with line to carb, no problems :!: :!:
''JUST MY TWO CENT'S WORTH'' |
Mine is mounted on the passenger fenderwell, when running gas with 2 #6 lines going too the carb. I have a duel setup with a 10 gal tank in the trunk and a 3 gal. for alcohol mounted left front for the injection.
Zip. |
[quote="mopar1968"]Mine is mounted on the firewall, with line to carb, no problems :!: :!:
I belive NHRA sais no fuel line can be within 2 inches of the firewall, for what its worth. Craig |
[quote="gnsrule"][quote="mopar1968"]Mine is mounted on the firewall, with line to carb, no problems :!: :!:
I belive NHRA sais no fuel line can be within 2 inches of the firewall, for what its worth. Craig[/quote 6" I believe :D :D for regulator, they get that I believe with the fact it states must be 6" forward of flywheel, bell housing area |
If you look at the pics in my profile you will see it mounted in passenger side of firewall, goes thru tech at every race, we race NHRA Track.
http://www.racingjunk.com/gallery/profile/163312/181736 ''JUST MY TWO CENT'S WORTH'' |
they get that I believe with the fact it states must be 6" forward of flywheel, bell housing area :wink: That is correct I got hit in tech 2 years ago for having the reg on the fire wall and had to relocate it. |
mark I used to have mine just like yours, first race they made me move it, some tracks are just not that picky
| All times are GMT -8. The time now is 04:36 PM. |
