-   In The Pits (https://www.racingjunk.com/forums/forumdisplay.php?f=18)
-   -   Dumbass me (https://www.racingjunk.com/forums/showthread.php?t=27488)
gnsrule 02-27-2010 12:31 PM
Dumbass me
So I pull out the work truck which is pluged in all the time and park it in the street. I pull out the Dodge and start going down the street and notice its got a tail....the frickin extention cord for the work truck block heater. Its all wraped up around the axle and inbetween the duels also. I cut out the cord and go on my way to a buddys trans shop. On the way home i find out I got squat for brakes. The cord ripped off the rubber hose going to the right rear caliper. Get home and rince off the underside from all the brake fluid and call around to find its a dealer item only and no one has it in stock. Ordered it up and now I have to wait till tuesday. Oh well, not the biggest problem around, just another one on the list.
Just venting
TheYellaBrick 02-27-2010 02:37 PM
Hey, Ya gotta have a dumba schitt movement once in a while to let you know you're still ALIVE !! :shock: :roll: :oops: :oops: :oops: :oops:
Scooterz 03-04-2010 09:48 AM
It happens to the best of us.... I will say you could not have found much more bad luck in that scenario. You ought to hear my Scooter story sometime... it does get worse.
gnsrule 03-04-2010 03:12 PM
And i get the line from the dealer. Suprised that its the 3 foot steel line and the rubber going to the caliper for only $20. Cant go wrong there. Snapped the mounting bracket bolt off, and broke the left rear bleeder off. Screw it, bled the right rear and zip tied the line. Done.
Craig
