-   -   small block chevy code? (https://www.racingjunk.com/forums/showthread.php?t=27503)
poncholvr 03-01-2010 10:44 AM
hi everyone i need some help on this im wondering what it is ,and the year i cant find it any where on the net
23362194 are the numbers on the block by the bell housing
F0277PD is on the front of the block
i believe its a 283, 1955, or 1965,need help please,thanks
leahymtsps 03-03-2010 09:09 AM
Re: small block chevy code?
You have too many #s for older blocks. I think you will find the casting # should be
3862194 283...65-67 Chevy II
PD ....65-66 283 with manual trans Chevy II
You can confirm this if the block is notched - recessed by the oil filter cavity.
Tom
poncholvr 03-19-2010 08:50 PM
thanks yes it is out of the chevy2 truck,
you guys think it is was good motor to build? is anyone interested in them?
what is a good price for a rebuildable motor?
zipper06 03-19-2010 10:42 PM
Never ever seen a chevyII truck, maybe i'm missing somthing here. The early chevy II's had a front oil filter and a front sump pan.
