-   -   ??carb for small block chev. 360?? (https://www.racingjunk.com/forums/showthread.php?t=27590)
Mike84camaro 03-13-2010 06:38 AM
I am getting ready to get my engine back from machine shop,.060 350 11.10 compr. small block, solid roller cam. Its going in a street/strip car...My carb. I have now is the 4779- 750... My question is , is it worth the money for me to buy an HP750, cam specs.
@.050 Int. dur. 246 Exh. dur. 253
Int. lift .585 Exh. lift .600
I never have owned a good carb. do they make that much of a difference. I know I left out alot of other info, Just trying to compair the two carbs... Thanks guys for any help
dragonmaster093 03-13-2010 08:23 PM
i have simular engine and all i had at time was 600 and its way to small have checked around and everyone says hp 750 is what i need so i thought id pass it on to you
JEFF69Z28 03-14-2010 11:39 AM
CALL PRO SYSTEMS OR AED THEY WILL SET YOU UP WITH EXACTLY WHAT YOU NEED.
spib 03-14-2010 12:25 PM
I got a new pro systems 4150 for my new motor, have heard good things abought them, will fire new motor on dyno april 14th
Mike84camaro 03-14-2010 05:56 PM
I will look up pro-systems on google,Hay guys, Thanks so far for the help
JEFF69Z28 03-15-2010 02:17 AM
PRO SYSTEMS YOU WONT BE DISSAPOINTED!
Mike84camaro 03-15-2010 02:36 PM
I contacted Pro Systems, They sent me back an email explaining what they could build for me and what it would cost... I am VERY impressed, and the cost is very resonable... Hay THANKS you guys looks like I found me a carburetor...
