-   -   oversize lifters in a BBC (https://www.racingjunk.com/forums/showthread.php?t=27599)
bigcrunch 03-13-2010 06:56 PM
I plan to bush the lifter bores in my 2 tall decks, I know some sized them to Chrysler roller lifters.
What is common these days?
hammertime 03-13-2010 07:56 PM
.903 Lifters seem to be what everyones using now days :)
hink 03-14-2010 07:16 PM
X2
bigcrunch 03-15-2010 01:58 PM
.903 = Chrysler?
different length pushrod comapred to Chevy?
BEAST477 03-15-2010 03:36 PM
In my 540 BBC it has Isky EZX .904 lifters and your push rods will depend on your deck height and if your heads have been cut. You will need a push rod length checker to determine what length you'll need.
Dahlton 03-15-2010 10:55 PM
I'm going to use Comp .904" lifters in my dart big m block but I'm having trouble finding the lifter bushings I have tried to contact CHE to get their bushings same as used in the chevyhiperformance magazine but they don't answer... Where are you guys getting the bushings? I'll probably make my own but it takes alot off time and is not that cheap...
zipper06 03-16-2010 07:52 AM
BHJ makes them and they considerably cheaper than CHE, they'll also answer the phone.
http://www.bhjproducts.com/bhj_conte...leeves/lbs.php
bigcrunch 03-16-2010 03:42 PM
can larger than .904 sleeves be used in a chevy tall deck?
Dahlton 03-19-2010 02:28 AM
Dang you were rght! :D they answered and if we can get a reasonable shipping prize I'll take them from there.
hink 03-19-2010 04:21 AM
We machine alot of the .904 lifter bores in both SBC and BBC and rarely do we install bushings when going to the larger lifter bores.
