-   GM LS engine talk (https://www.racingjunk.com/forums/forumdisplay.php?f=21)
-   -   2003 VETTE BACKFIRE/BUSTING OUT (https://www.racingjunk.com/forums/showthread.php?t=27629)
BRENTHOB 03-18-2010 07:39 PM
:x I HAVE ALOT OF PERFORMANCE WORK DONE TO MY CAR,EX,NOS,CAM ,ITS BEEN RUNNING GREAT UNTIL ABOUT 2 DAYS AGO AND WHEN YOU GO PAST 1/2 THROTTLE IT FALLS ON ITS FACE AND BACKFIRES THROUGH THE EXHAUST UNTIL YOU LET OFF OF IT AND THEN IT RUNS PERFECT,ANY IDEAS?
MEMRACING62 03-18-2010 08:08 PM
sounds like fuel starved, check filter, fuel presure & volume. possible pluged sock in fuel tank. if you have a fuel cell possible foam from fuel cell pluging up filter.
ddwspringer 03-20-2010 02:42 PM
yup sounds like a lean condition to me check you're fuel delivery system
ashbros 08-14-2013 07:41 PM
call me crazy, but I just experienced the same thing while running on the dyno with a new build. The short of it was I was a little low on tranny fluid. There are built in electronics in a corvette that shut down the motor just as you described. I know I probably gonna catch a little flack on this one, but that was the fix.
bjuice 08-27-2013 05:16 PM
No sir..I can believe every word you said with all the computer controlled stuff today.
Good to see u old friend !
